Sponsored by: CARiD
Range Rover L322 - Engine Oil
Old May 26, 2024 | 11:27 AM
Awale23's Avatar
6th Gear
Default Range Rover L322 - Engine Oil
Hi all
My oil needs topping up. Can’t remember what the garage used last time.
The manual says 5W30 ACEA A3 and B3.
I seen the Castol Edge 5W30 but it has ACEA C3.
Can I still use it?
Any help would be great
Old May 27, 2024 | 01:36 AM
nimmi234's Avatar
5th Gear
Originally Posted by Awale23
Hi all
Can I still use it?
Hey there,
It's important to use the right oil for your Range Rover. While Castrol Edge 5W30 is good, it has a different rating than what's recommended in your manual.
To be safe, it's best to stick with what the manual suggests (ACEA A3/B3). If you're unsure, it might be a good idea to call your garage or ask a mechanic for advice.
Hope this helps!
Awale23
Range Rover L322 (3rd Gen)
May 22, 2024 11:26 AM
Brosenblum
Range Rover L405 (Fourth Gen)
May 4, 2024 05:19 AM
Jazzyj
Jan 2, 2024 06:40 PM
lschwarcz
Nov 2, 2020 04:45 PM
