Rear Air Suspension - '01 Disco II - Take 2
#21
on
RE: Rear Air Suspension - '01 Disco II - Take 2
ORIGINAL: lrobin3w
are you very attatched to the air suspension? why not convert the rear air susp to coil spring susp and forget about it? $250 for kit.
#22
I'm looking at 3 options:
1. New compressor at around $500.
2. Used compressor at around $300.
3. Convert to springs.
What is the downside to #2? Is there a high probability that used compressor will fail quickly?
Even though I am no mechanic, I am thinking about replacing compressor myself. Someone said an 'idiot' could do it. Are there diagrams/instructions?
Thanks.
Thanks.
#24
"it is pretty much plug and play. "
Finally received compressor and thought I might try to put it in.
Taking case off was 2 easy screws - but the rest doesn't look so easy. I don't see how I can easily access all the screws/wires.
Does the whole componentcase have to come out (unscrew bolts that hold case to frame)?
And then when entire case is out of truck I can screw/plug easily, then put everything back?
Or can it be done while lying on back under truck?!?!?
#25
#26
on
ORIGINAL: D2000
Does the SLS systems need any regular maintenance?
How often does the SLS filter need to be changed?
I like the system but would like to minimize any chance of failure.
#27
on
ORIGINAL: Charles68
Does the whole component case have to come out (unscrew bolts that hold case to frame)?
#28
OK. Its going to be dark soon. I started unhooking old compressor. The only things left are the two heavy black hoses (top andleft side). What is the trick to pulling them out? Is it just brute force? There doesn't seem to be any loosening nut.
Once I get compressor totally disconnected from vehicle I will have room to swap it with new one - then reconnect everything.
Please advise...
Please advise...
fastrx7man
01-28-2012 12:49 PM
catchthebig1
09-24-2010 11:57 AM
bobbydave
10-31-2007 08:15 AM
