Sponsored by: CARiD
Rear windows on Disco I - wont work
Old Oct 2, 2007 | 10:48 AM
bhorwhat's Avatar
Default Rear windows on Disco I - wont work
I have a 99 Disco I - original owner with 180K miles. Two days ago the rear windows failed to operate. Both front widows work - these are on the same fuse. I checked the fuse anyway but they were fine.
Anyone have an idea as to what to check next for troubleshooting this. I tried both the front and door switches - nothing.
Any assistance would be much appreciated.
Bob
Old Oct 2, 2007 | 11:17 AM
Default RE: Rear windows on Disco I - wont work
First, I have to ask, how did you get that many miles on your 99, I only have 94,000 miles on mine.
As for your windows, the body ECU that operates your windows has failed, pretty common, but it is usually a cracked circuit board that can be repaired easily.
Old Oct 2, 2007 | 11:26 AM
Landzu's Avatar
The window ECM behind the glove box needs to be fixed
or replaced.
This is a normal thing with Disco I's
Old Oct 2, 2007 | 11:31 AM
bhorwhat's Avatar
Mike - mainly all highway miles - although Im an avidoutdoorsman and the Disco has allowed me access to some areas I wouldn't have tried to traverse before. Thanks for your response - If you have a moment - can you describe how to access the ECU and where I can purchase the module (pref. aftermarket) if I cannot determine it can be repaired.
Im an engineer and fairly handy - I've done the bulk of the repairs on the vehicle to date.
Thanks again
Bob
Old Oct 2, 2007 | 11:59 AM
Landzu's Avatar
You can do a search for this, it was posted
with pic's on what to do to fix it.
Old Oct 2, 2007 | 04:20 PM
Look hear for a good price on a guaranteed used part.
http://www.roverlandparts.com/index....TS&Category=62
Old Oct 2, 2007 | 07:44 PM
Landzu's Avatar
ORIGINAL: bhorwhat
Bob
Look in the Disco forum under the ((((96 Disco Window Issues))))
it has a like to fix your Disco I.
Old Oct 3, 2007 | 03:50 PM
Landzu's Avatar
Heres the link for the rear windows.
http://www.discoweb.org/window/index.htm
Old Oct 4, 2007 | 02:31 PM
bhorwhat's Avatar
Landzu,
Thanks - you and the others have been very helpful. This is by far the best forum I've found for my Disco. I had actually found that tech. report and printed it.
Interestingly enough, the windows decided to work two days later but I made the mistake of leaving one rear window down and today, of course, it won't go back up.
I may have found a cheaper work around solution - Atlantic British sells an ECU by-pass for the rear windows. I don't know how it works....it lookslike a cable with a fitting on either end. They say it comes with instructions and is only $14.95. I'll let you know if and how it works. If it doesn't, I'll pull the ECU and see if I can determine whether I can resolder the connection or if it needs replaced.
Old Oct 5, 2007 | 03:40 PM
Landzu's Avatar
I would like to know if you get the cable let me how it works.
I pulled mine apart a few years ago and fixed the Window ecu
but the first time I went off road it was back to the 5min wait before
the rear windows would work.
So if the cable bypasses it ecu I think I'm game.
Good Rovering
