Sponsored by: CARiD
Replaced Airbags with Springs
Old Sep 26, 2017 | 09:20 AM
Jimmyjam's Avatar
8th Gear
Default Replaced Airbags with Springs
I recently replaced my rear airbags with springs and a couple days later my battery was dead. I couldn't find anything that was left on, so I am wondering if I need to disconnect the air compressor or plug the lines that ran to the airbags? I am wondering if it keeps trying to inflate the bags and therefore continues to run.
Thanks in advance!
Old Sep 26, 2017 | 09:33 AM
mollusc's Avatar
Did you change the settings using a programmer device to tell the truck that you don't have air springs any more? That should stop the compressor from running.
Old Sep 26, 2017 | 09:37 AM
Jimmyjam's Avatar
8th Gear
I did not. I don't have a programmer. I just removed the leveling fuse and relay, but I have read that the leveling relay is also responsible for ABS working, so I assume that's not the best option. Is there a generic programmer that I should buy for my D2?
Old Sep 26, 2017 | 10:12 AM
Sixpack577's Avatar
Where are you located?
If you're close to south central Va, I'll turn it off, no charge. I have a Hawkeye.
If you're not, maybe another member close to you can help. Beats spending the money and waiting on it to arrive for just one thing. Although an obd2 with LR software is a good tool to have if you do your own work.
Old Sep 26, 2017 | 10:14 AM
Jimmyjam's Avatar
8th Gear
Thanks, but I'm in Montana. I posted on a local forum also and I believe I have found someone with a diagnostic tool to turn it off for me.
Old Sep 26, 2017 | 10:24 AM
wjsj69's Avatar
In the mean time, you could disconnect the wires going to the compressor, and/or use cable ties to keep the level sensor arms in place so the system thinks it's level..
Old Sep 26, 2017 | 05:56 PM
mollusc's Avatar
Level doesn't matter. Height matters.
Old Sep 27, 2017 | 08:13 AM
wjsj69's Avatar
You're right, i used the wrong term; edit: use cable ties to keep the RIDE HEIGHT sensor arms in place so the system thinks it's AT THE CORRECT level..
Old Sep 27, 2017 | 09:27 AM
number9's Avatar
Keep it simple, remove connector C0780 at pump and the pump will not drain your battery. Pump power comes from FL9 via SLS relay R5/R216 in eng compt fuse box so there's not an individual fuse too remove.
Old Oct 31, 2017 | 11:29 AM
Jimmyjam's Avatar
8th Gear
Thanks number9, which connector is the C0780 connector? I see a blue and white connection at the front of the pump.
