Sponsored by: CARiD
reset
Old Nov 7, 2007 | 01:06 PM
pdv83's Avatar
8th Gear
Default reset
hi, i removed my batery to charge it and now when i turn the key to start my display tells me windows not set how do i set all the items it need resetting. help please the bleeps are cracking me up.
cheers
david
Old Nov 8, 2007 | 07:37 AM
Default RE: reset
Year and model will help. Don't you have your owners manual, it is spelled out in there in great detail?
Old Nov 8, 2007 | 05:43 PM
pdv83's Avatar
8th Gear
Default RE: reset
hi, its a p38 1998, i have the manual but i cant find anything about reseting windows, cheers david
Old Nov 10, 2007 | 02:51 PM
pdv83's Avatar
8th Gear
Default RE: reset
does anyone know where i could find out.
cheers
david
Old Nov 10, 2007 | 03:15 PM
Default RE: reset
It is in the owners manual, look closer.
Wish I could help.
Old Nov 13, 2007 | 03:39 PM
Savannah's Avatar
Default RE: reset
Hi David
Follow the following procedure to set the windows and sunroof.Switch on the ignition.Start with any window and press the down button.As the window goes down you will get an audible and visual message that the window is not set.When the window reaches the bottom release the switch.Now press the up button and do not release the button until the window reaches the top.Hold the switch untill the dashboard gives you a message WINDOW SET. Now do the rest of the windows.Open the sunroof all the way without releasing the switch.Close the sunroof without releasing the switch.Release the switch and press and hold it again until the sunroof tilts up and hold it untill the dashboard give a message SUNROOF SET.Problem solved
Regards
Marius
Old Nov 13, 2007 | 04:04 PM
pdv83's Avatar
8th Gear
Default RE: reset
hi, thankyou marius i did find it in the manual but it does not explain it as you did. i did try what the manual says but it did not work i will try it the way you have said. thanks again.
cheers
david
Old Nov 19, 2007 | 01:17 PM
pdv83's Avatar
8th Gear
Default RE: reset
hi marius, that worked perfect, dont understand why someone else could not have just told me that instead of cryptic clues. but i thankyou for your help.
cheers
david
eameglio
Jun 13, 2009 05:05 AM
eameglio
Mar 30, 2007 04:57 PM
ny1999
Mar 4, 2007 05:46 PM
ajordan_0012000
Mar 3, 2007 05:57 PM
jmang
Oct 22, 2006 11:25 AM
