Sponsored by: CARiD
Rotating tires and aligning every rotation?
Old Nov 19, 2010 | 11:42 PM
dustinvonholten's Avatar
Default Rotating tires and aligning every rotation?
I read on a forum that every tire rotation you need to tire align.
That does not make sense to me, I thought tire aligning was only when you get new tires. My tires are aligned fine and I have rotated 5 times since I bought new tires, every oil change.
Confused, any thoughts or frustrations about reading that you need to do this, potential agreements?
On the other hand, if you install a new drive shaft do you need to tire align -- my own separate question as I am getting a balanced ..... Tom Woods shaft soon by mail.
Old Nov 20, 2010 | 02:20 PM
Rovin4life's Avatar
if you own your own alignment machine then by all means go for it. Otherwise rotate the tires and check for abnormal wear and make sure nothing is loose.
Old Nov 20, 2010 | 09:12 PM
The driveshaft has nothing to do with tire wear.
The only reason you rotate your tires is so they wear out all at the same time.
The only reason you would need a alignment is if you had irregular tire wear, which you will never notice if you are rotating your tires at every oil change.
If you are driving on a flat straight road at 60 mph and you can take your hands off the steering wheel and the truck stays straight for at least 10 seconds your alignment is fine.
Old Nov 21, 2010 | 11:40 AM
Thank You. The responses are in "alignment" with my perspectives.
Old Nov 22, 2010 | 12:13 PM
Paul Holmes's Avatar
Banned
If you have to do it yourself, here's how.
Jack up the truck and exchange the first tire with the SPARE TIRE. Then take the removed tire, and exchange it for the next tire in the rotation order. Then exchange that tire for the next and so on. Lastly, you'll exchange the last tire to be rotated with the spare you installed in the first place. All 4 tires changed, and all with one jack.
Old Nov 23, 2010 | 05:08 PM
Default Instructions
I like the front to back route, and save the spare tire with a tire cover.
Bought tires on c-list brand new, had a auto shop install and now get free tire rotations even though I did not buy their tires thru warranty. Takes an hour, but it is near a mall so I don't mind.
dirtlord
May 21, 2013 10:31 AM
TRIARII
Oct 29, 2012 01:01 AM
sparky
Apr 25, 2011 08:58 AM
salve7
Jan 21, 2010 01:22 PM
mwsharb
Mar 12, 2009 09:35 AM
