Sponsored by: CARiD
rust removal and repaint for brush guard
Old Sep 13, 2007 | 01:09 PM
Disco2Guy's Avatar
Default rust removal and repaint for brush guard
I'm getting a used front brush guard for my 01 Disco 2 that has some rust on the corner bend. It looks like the paint was scraped off from rubbing against a wall (the frame itself is not bent) and now has a top layer of rust. After I remove the rust, what type of paint should I look for to seal the metal again. I'm not sure if these are actually powder coated of if it's another type of paint.
thanks
-D2G
Old Sep 13, 2007 | 03:27 PM
Default RE: rust removal and repaint for brush guard
They are usually powder coated when built.
Might just go buy some Rustoleum in a color that matches, sand down the area to be painted a give it a couple coats of paint.
Old Sep 13, 2007 | 04:43 PM
Disco2Guy's Avatar
Cool, that's pretty much what i was hoping to hear.
Old Sep 13, 2007 | 11:29 PM
Bill E's Avatar
You can get powder coating touch up paint in a spray can, problem is if it is black there are a number of 'Blacks' on the market, also the original will have some sun damage so what ever you use will probably show up.
smokinwheels
May 25, 2021 11:11 PM
Josh.0
Sep 23, 2012 09:24 PM
Vertigo RT
Aug 25, 2010 12:06 AM
Roverboy3766
Dec 6, 2007 03:42 PM
Brad S1
Sep 23, 2006 11:10 PM
