Sponsored by: CARiD
sat nav problems
Old Jul 23, 2007 | 07:24 AM
roymoo's Avatar
Default sat nav problems
The sat nav on my 2001 P38 4.6 vogue has developed a blank white screen, the disc holder in the rear also now keeps discharging & re engaging the cd disc. At this same time I have lost the volume control on my radio. Would be grateful for any solutions .Regards.
Old Aug 22, 2007 | 02:40 PM
LrTECH's Avatar
Default RE: sat nav problems
replace nav unit
Old Sep 18, 2007 | 04:20 PM
Surfrider1468's Avatar
4th Gear
You may want to check your wiring from the battery to the main fuse/relay case under the hood. My Nav wasfried because of a shortbetween the battery and the main fuse box.Being that I didn't use the Nav very much, didn't have the $1800 to replace it,and only wanted my volume control back, I rewired the stereo around the Nav controler in the back. Without this, the Nav amp will continue to mute the Radio down to a "moderate colume" until it is replaced. ($1800)
merry
Off Topic
Sep 9, 2008 02:52 AM
Range Roguer
Sep 29, 2007 01:29 PM
smiffy
Mar 10, 2007 02:56 PM
jasflora
Mar 25, 2006 02:05 PM
malcolmk
Nov 4, 2005 01:56 PM
