Sponsored by: CARiD
self leveling switch?
Old Oct 7, 2009 | 05:02 PM
clockmaker21's Avatar
5th Gear
Default self leveling switch?
I have a 2001 diso II that sometimes drops it's rear. When I start it up it takes a couple minutes to level. It does not do it all the time...just sometimes? Is this a self-leveling switch problem? If so how much of a hassle is it to correct?
Old Oct 8, 2009 | 11:40 AM
CCROVERSE01's Avatar
I have the same problem, but it is my airbags. At 120K+ they are due. No problem when temp above 40F. but drops occasionally when colder or carrying a heavy load in rear. I will be replacing in 2 weeks.
Old Oct 8, 2009 | 12:11 PM
First, that is not a self leveling switch, might want to read up on it in your owners manual, it is for off road wheeling only and for speeds under 20 MPH, I believe.
Never use it to try and raise a sunken rear end, you will just add fault codes to the ecu.
You might want to send me your number and I will walk you thru what is going on and what to do.
Old Oct 8, 2009 | 12:13 PM
When ordering new bags, buy only the new 3rd. generation Bag from Arnott Ind., better then the factory bag for less money and a lifetime warranty.
Old Oct 8, 2009 | 03:31 PM
Thanks Mike,
That is what I am buying. They are on Ebay right now for $269.00 a pair with free shipping!
Old Oct 10, 2009 | 09:06 PM
5th Gear
If it was the air bags fault...it would consistantly leak. The back end would drop always. It has to be electrical. Something that is not "reading" correctly. If it was an "air leak" it would be consistant....always loosing air presure. My number is 1-800-243-2498 I am by myself and work for myself so leave a phone number if I don't pick up. I really appreciate any help as the local dealer is ruthless! Patrick
Old Oct 10, 2009 | 09:09 PM
5th Gear
P.S. I really appreciate all your input and help! Patrick
echo46
Oct 19, 2020 12:13 AM
NESkier
Mar 1, 2015 06:59 PM
fourwheel
Feb 1, 2009 09:32 AM
robdis96
Jan 3, 2008 02:54 PM
dailyuser
Dec 31, 2005 06:22 PM
