Sponsored by: CARiD
SES: 0171, 0174, 0734
Old Apr 1, 2008 | 08:56 AM
Charles68's Avatar
Default SES: 0171, 0174, 0734
Greetings all.
As usual, my deadline for inspection passed yesterday and both vehicles have engine lights on.
'01 Disco II SE7 ran codes: 0171, 0174, 0734 a few months ago when light came on. Can I do something to clean MAF? Or should I just get new one?
Also, and this is really stupid... I can't seem to get air filter cover off to replace air filter. I have no recollection of when it was changed last. Could it simply be old air filter causing this?
I unhook the 2 clamps to MAF. I unhook the 2 clamps on filter housing. It looks like there are 2 tabs on front side of filter housing and I'm not sure what level of brute force to apply to disengage the tabs. Are they sort of hinges? Do I push MAF away while pulling air hose to front while lifting a bit to separate the MAF from filter housing/hose?
Advice appreciated!
Old Apr 1, 2008 | 09:20 AM
Default RE: SES: 0171, 0174, 0734
You have to replace the MAF, a Bosch MAF can't be successfully cleaned.
As for removing the top, i take the 2 MAF clips off, remove the 2 air filter box clips and pull the MAF up a little so you can pull the nose of the air filter top up.
Call Tony at Cerrones, 650-365-4145, he still has the best price on line at around $160. Tell him Mike says HI.
Old Apr 1, 2008 | 10:12 AM
Charles68's Avatar
Hi Mike,
I emailed Tony earlier this morning - waiting on price. Thanks.
Old Apr 2, 2008 | 01:37 PM
Charles68's Avatar
I got filter housing open and under the old air filter there was a pile of pine needles, leaves, and previously chewed acorns.
Is it often that critters sneak in under wheel well? Should there be some kind of screen to keep them out?
skunkridge
Sep 17, 2024 05:47 PM
outdoor7or24
Dec 16, 2013 05:13 PM
merrion13
May 16, 2013 07:53 AM
riko suave
Jan 2, 2013 04:58 PM
Disco_Fever
Apr 26, 2011 11:59 AM
