Sponsored by: CARiD
shift gear lever
Old May 17, 2008 | 12:26 AM
roving patrol's Avatar
Default shift gear lever
Hey fellas,
Quick question, I noticed just right now that the metal part of my shift gear lever gets really hot after just a few minutes of driving! By the way, the truck is automatic. Is this normal and juat a cause of the bulb that illuminate the shifting gear ( p,r,d,123)?
Old May 17, 2008 | 10:08 AM
tee51397's Avatar
Default RE: shift gear lever
Check your transmission fluid level and condition. While you're under there check your x-fer case fluid too for good measure. The transmission does generate heat, so some heat is normal but do check that fluid.
Old May 17, 2008 | 05:23 PM
Pretty normal.
epcdiscoII
Feb 14, 2014 10:28 PM
ihscouts
Jan 1, 2014 07:41 PM
Tvdmtac
Sep 10, 2007 02:05 PM
martinez
Engine & Internal
Jun 3, 2007 04:47 PM
