Sponsored by: CARiD
SRS problems and leaking heater core
Old Jun 2, 2008 | 04:19 PM
thoward's Avatar
6th Gear
Default SRS problems and leaking heater core
I'm new to the forum, looking for my first help! Just purchased a 2001 Discovery II SE7. Needs a little TLC, but overall in good condition. My first project was to tune up the engine - new plugs, oil change, etc. When I took it for a test drive, I noticed the SRS warning lite is on the dash and the cruise doesn't work now. I'm guessing something got bumped/unhooked. Any suggestions?
Also, I knew it had a leaking heater core, so have temporarily bypassed with a piece of copper tubing. Any words of wisdom when it comes to removing the dash and replacing the heater core?
Tom
Old Jun 2, 2008 | 10:24 PM
roverguy7's Avatar
Default RE: SRS problems and leaking heater core
heater cores are a pain in discos, you got some bad luck, ive worked on probably over a thousand different ones, and replaced 1 heater core, not fun. anyway, youre going to need to get your srs codes read to be sure, and make sure that you're using the you have the cruise master switch turned on, but if theyre related its going to be your clock spring behind your steering wheel, if you have a fault for driver frontal airbag, its the clockspring. if not, then its going to be a pretensioner, and can generally be corrected by some di-electric grease in the connector.
Old Jun 3, 2008 | 03:20 PM
thoward's Avatar
6th Gear
So the cruise issue was just a newbie goof on my part. Yup, the master switch on the dash was off. I'm picking up an OBDII reader this week, so will check out the codes.
Tom
Old Jun 3, 2008 | 08:09 PM
roverguy7's Avatar
unless youre spending big money, youre not going to be able to read your srs codes, standard code readers will only read engine and trans codes
Old Jun 9, 2008 | 12:33 AM
rvrguy's Avatar
ya the srs your probably going to have to take it to the dealer to read the code.if you do the heater core just remeber which connectors go to what.im done 1 core with out pulling the dash but its just easier to remove it.
Old Jun 9, 2008 | 05:06 PM
thoward's Avatar
6th Gear
I hooked up my OBDII reader, cleared the codes, drove for a couple hours on the highway. SRS is still on and although the service light isn't on, Code P1590 (rough road code?) is still on. Guess I will have to take it to the dealer.
Tom
98NiagaraRR
Sep 19, 2012 10:26 PM
DiscoRover007
Aug 22, 2012 06:20 AM
Aardvark
Jan 24, 2011 07:19 PM
tex599
Jun 22, 2009 10:03 AM
