Sponsored by: CARiD
starter on 89 classic
Old Nov 28, 2007 | 11:53 AM
colton's Avatar
5th Gear
Default starter on 89 classic
I have an 89 classic. I repaced the original starter because at times it would work and some times I would turn the key 10 -15 times then it would turn over and start. No problems for 6-8 weeks. On Sunday turned the key and no starter. I looked over a wiring diagram and saw that there is a starter relay. So I pulled it and traded with the a/c relay to see if that would work but still no starter. Cuold the new starter have a problem? Looking for some help.
Old Nov 28, 2007 | 01:16 PM
Default RE: starter on 89 classic
Sure it could have a problem. Did you install a new or a rebuilt starter? If it was a rebuilt, they fail alot because of the quality of the rebuild.
Other then that, ignition switch, solenoid, wiring and wiring coul be causing your problem.
Old Nov 28, 2007 | 01:25 PM
colton's Avatar
5th Gear
I put in a new after market starter. When I turn the key I can hear a click from a relay around the front seat could that be the fuel pump relay? Can you give me an idea of what to look at next? Does it have a neuteral safety switch?
patrolman4
Nov 6, 2023 07:48 AM
sna77
Sep 16, 2023 08:10 AM
Gimebakmybulits
Jul 14, 2014 05:57 PM
johnkbl
Apr 23, 2012 07:49 PM
hsmatharu
Defender
Aug 23, 2006 12:33 AM
