Sponsored by: CARiD
Starting
Old Apr 9, 2009 | 08:18 PM
RoverDan's Avatar
Default Starting
I have a 96 Disco that has a problem starting. Not sure if it is the fuel pump or the starter. It eventually starts after a few minutes of starting and pumping the gas pedal. Need help any suggestions?
Old Apr 15, 2009 | 09:10 PM
oldrovertech's Avatar
get some diag tools and a manual. fuel pressure tester, check your air filter, read the manual. it will help you out, and if you get confuzed come back and post your thoughts =)
Old Apr 16, 2009 | 08:21 AM
If the engine turns over it is not the starter.
From your statement, sounds like you have little experience, but there are a couple things you can do. Change your fuel filter, if you are still having problems, send me your tele number and I'll call and walk you thru some other ideas.
Old Apr 16, 2009 | 08:22 AM
antichrist's Avatar
First, you shouldn't be pumping the accelerator when you are starting it.
Second, need a better description of what it's doing.
Does it crank at normal speed and just wont start?
Does it crank slowly and then eventually starts?
Old Apr 17, 2009 | 08:30 AM
RoverDan's Avatar
In the morning when i first try to start it. It turns over but doesnt stay running it putts then shuts off. After my 5th time of turning on and shutting off it stays on. And after that it runs fine. But once in a while it will go to a extremely low idle and i would have to give it some gas (gas pedal) to keep it running.
Old Apr 17, 2009 | 10:24 AM
So when was it last tuned, what have you done to find the problem? Consider cleaning out the t/body and remove and clean the idle control unit.
If you still have problem, PM me your tele number and I'll call you.
lazerbrains
LR2
38
Aug 9, 2023 07:54 PM
brian.arthur
Freelander
Mar 14, 2006 04:32 PM
asmcmillin
Apr 10, 2005 12:16 AM
aldenplanthire
Jan 22, 2005 08:15 AM
devildogrover
Dec 24, 2004 04:48 AM
