Sponsored by: CARiD
steaming exhaust
Old Aug 25, 2006 | 02:58 PM
ssonic's Avatar
4th Gear
Default steaming exhaust
help im new to this computer world. can anyone give me advice on my disco2 td5 it,s got 80.000 thousand mile,s full land rover history . in the mornings when first started it steams from the exhaust and theres a smell of anti freeze after about ten minutes running it clears up. It do,s not overheat even towing a heavy trailer go's fine and has no power loss. i have started topping up the headertank every week now . . to me it sounds like the head gasket has started to go but i can not understand why it is not overheating which i took to be a sign for the head to have go.If this is the case' would i be able to replace the gasket my self i have some experiance with engines and have replace a head gasket on a petrol car before if so would i need any special tools uther than a torque wrench hope this gives a good discription off my problam please excuse the spelling and such look forward to any advice given thanks for now
Old Aug 25, 2006 | 03:25 PM
Default RE: steaming exhaust
Yes, you have a failing head gasket, take it to a good shop, there are a cople quick tests they can run to verify the problem.
Do it sooner then later so you don't do any head damage.
Mike
Old Aug 26, 2006 | 06:51 AM
ssonic's Avatar
4th Gear
cheers disco mike can you advice on the matter off me removeing the head my self and getting it pressore tested and if necassery to skim the head and refit it my self look forward to a reply cheers again. ssonic
Old Aug 26, 2006 | 11:09 AM
I haven't worked on a diesel before so I won't be much help. But go to a shop and have them presure test the coolant system for internal leaks inside the engine, only take 5 minutes then at least you will know if you have a problem.
Mike
Old Aug 26, 2006 | 07:13 PM
ssonic's Avatar
4th Gear
thanks again mike for your time and advice will let you no how i get on cheers for now . ssonic
robdis96
Headers, Intake, & Exhaust
53
Dec 20, 2013 07:11 AM
twaszak
Jul 15, 2012 07:21 PM
Street Wolf
Jun 24, 2011 01:59 AM
Viper3812
Sep 13, 2007 05:33 PM
Randy Lover
Freelander
Oct 30, 2005 09:01 AM
