Sponsored by: CARiD
Steering sticks and is loose
Old Jun 14, 2014 | 11:43 AM
parke's Avatar
Default Steering sticks and is loose
First off I want to make it perfectly clear that I know NOTHING about Land Rovers. I recently bought my first and am in the learning curve
I am very mechanically inclined though and the only Rover shop around is the dealer (I refuse to go there). The steering issue that I am having is that when I turn a sharp right (turning a corner) the steering sticks to the right position. It is not a power steering issue. I can hear and feel a pop in the steering column. This only happens when turning right. The steering is also loose with a lot of free play when driving down the road, I'm thinking maybe a new steering box and rack rebuild, but I am much more familiar with engines than steering/suspension. Any help would be appreciated, Thanks!
Old Jun 14, 2014 | 01:36 PM
jafir's Avatar
My crystal ball tells me that you drive a pink Freelander. Is it right?
Old Jun 15, 2014 | 12:13 AM
parke's Avatar
Yes, it was my gift for selling a LOT of Mary Kay. My apologies, I did forget to mention that it is a 2000 Discovery.
Old Jun 15, 2014 | 10:31 AM
jafir's Avatar
Maybe ujoints in the lower shaft?
My 2003 steering would bind when a motor mount broke as was pressed up agains the shaft.
Old Jun 15, 2014 | 10:46 AM
parke's Avatar
Motor and trans mounts are fine. I will check and grease the u joints and keep updates about the situation. Thanks!
Old Jun 15, 2014 | 10:48 AM
jafir's Avatar
Also if there steering is loose, I'd check all of the tie rod ends. If one is messed up it might be binding I suppose.
Old Jun 15, 2014 | 11:31 AM
tuercas viejas's Avatar
Urgent
Before doing anything on a Flandie steering rack check to see if it has torn away from the bulkhead.
The driver's side is most affected where the bolts sheer off. Mostly due to long term in security of the rack!
The nutserts inserted on production which take the 10mm bolts are hidden inside a box section and it means removing the whole rack & dropping the power pack or boring two holes in the body from the driver's floor area.
Don't ignore this possible issue; ultimately the rack can detach itself from the vehicle and you will have no steering.
Get a Professional to check your steering immediately.
I have fixed three such incidences one was the cause of an accident!
T/V
Old Jun 15, 2014 | 11:42 AM
jafir's Avatar
Originally Posted by tuercas viejas
Urgent Before doing anything on a Flandie steering rack
It's a disco. My crystal ball was wrong.
Old Jun 15, 2014 | 12:41 PM
Yes And I just saw Flandie mentioned!
Just that the last vehicle of this type I fixed with this problem on also had body damage having collided with a motorcycle at speed. Killed the rider!
All the more reason I suppose to have the steering checked if you are unsure of the problem.
Cheers T/V
Old Jun 15, 2014 | 07:31 PM
scootyg69's Avatar
I had a leaking box when I bought mine, dealer put in a used one, there was a dead spot that locked up when turning right. I had to change it again and have had no issues since. Scared the wife enough that she refused to drive it
