Sponsored by: CARiD
Still overheating disco2
Old Sep 30, 2010 | 02:07 AM
  #21
ncaramonta's Avatar
3rd Gear
Sounds like the same trouble I am having. Coolant was a little low so I added some and then about 10 minutes later it was coming out at high pressure from the overflow hose. I know I didn't bleed it right so I parked it and decided to look here for help.
Any help would be great.
2004 Discovery II HSE 4.6L
Last edited by ncaramonta; Sep 30, 2010 at 02:30 AM. Reason: Added make model and year
Old Sep 30, 2010 | 06:31 AM
  #22
If you want some help, send me your tele number and I'll call and walk you thru what to do and check.
Old Oct 1, 2010 | 01:29 PM
  #23
ncaramonta's Avatar
3rd Gear
I would love the help. I am new to the forum and don't see a way to send private messages.
Old Oct 1, 2010 | 03:22 PM
  #24
hilltoppersx's Avatar
click on their name on their post.
Old Oct 1, 2010 | 03:27 PM
  #25
Didn't notice you were new her so you can't PM me yet.
mjdiscomike21@gmail.com
Old Oct 1, 2010 | 09:16 PM
  #26
ncaramonta's Avatar
3rd Gear
Thanks I just sent you an email.
Old Nov 20, 2010 | 10:03 AM
  #27
DiscoRichard's Avatar
Just joined the forum, having almost same problem on a 2000 P38 4.0. Replaced head gaskets, radiator a couple of thermostats flushed heater core, pressure holds steady. Heat is low at idle, and I notice bubbles going into coolant reservoir one every 10 seconds or so even after driving for a bit. Temp holds fine at idle and can test drive a few miles with no problems, then all of a sudden it overheats. Its driving me crazy.. would like to talk to Disco Mike if possible. Thanks !!
Old Mar 15, 2011 | 09:30 AM
  #28
jamesimm's Avatar
Im i the same boat..replaced the lines, hoses, t stat, radiator, and my truck 99" Disco II does the same thing good for a 20 minute drive then BAM overheat. What is this mysterious desease? HAve you had any further luck with it? Let me know!
Old Jul 31, 2011 | 02:57 PM
  #29
2004S's Avatar
I am about to drain the coolant on my 2004 MY Discovery due to unexpected overheating issues last week. I have a new Thermostat from the Bellevue dealer, but the RAVE .PDF I think is not for the MY 2004 engine? I could be wrong about that.. But my question is where is the coolant drain plug? I think it's right next to the oil filter - lower left as you look at engine. (Both of the plastic pan covers obscure most of the engine & will not come out unless I remove the steering damper.)
Old Jul 31, 2011 | 03:38 PM
  #30
2004S's Avatar
Re-checking the RAVE .PDF again, I can see 1 screw bolts on LH engine block directly 18" below Oil filler pipe. This is a hexagonal bolt orientated upwards. I would think that to release coolant fluid they would point down, & the Workshop .PDF shows square headed bolts.
The major visual blocker is the plastic under pan panel that only has the circular access panel for changing the oil filter.
I can not remove this plastic panel due to the steering damper being in the way.
(Car is in my garage at home and I can not get enough leverage on the bolts to remove the damper by just lying on the ground underneath, the car needs to be raised which I currently do not have the equipment for.)
As you can see I am new to this forum so any direction would be appreciated.
Last edited by 2004S; Jul 31, 2011 at 04:52 PM. Reason: double checked location of bolts on Cyl Blk.
