strange EAS problem !
hi to all,
eas problem with my 96 RR
problem =
left side of the car (front & rear !) most of the time is about 1 or 2 cm higher than
the right side of the car, sometimes the difference is much more and up to 4cm
occasionaly (only happenen several times over 2 days) car indicated eas-problem
went to dealer
the eas "bags" are less than 1 year old, so i guess they are not the source of the problem,
anyways, the car goes up & down normally
dealer hooked car up to computer - eas code error said = problem with all 4 height sensors
dealer said = very strange and very unlikly - he noticed that my eas compressor had only
6 (cant remember what) and it had to be 10 (something with pressure)
so, dealer put in new compressor
BUT :
still had 2 eas warnings over 3 weeks time
and, sometimes the left side is higher than the right side again,
sometimes up to 4 cm
car rises & lowers normally
another remark, sometimes while driving in normal position
and keeping it in normal position, when i stop at an intersection
the car rises suddenly and lowers back without me doinig anything
and without any chages in the indicator lights of the eas push button
finally,
what could be wrong with the eas, knowing that bags & compressor
are new, but still, difference in height between left & right side
any good advice would be greatly appreciated !
i am going back to dealer this week and would like to be well informed
problem =
went to dealer
BUT :
finally,
The dealer should be able to perform a calibration procedure on the EAS ride height sensors. They use a scanner such as an Autologic unit ---to do this. The tech can set the ride height wherever he wants to-- on each corner----measure ground to wheel arch height with a tape, and set the new values as the norm . If a particular ride height sensor is not responding correctly, it must be replaced.
regards,
Geoman
www.eurotekapg.com
regards,
Geoman
www.eurotekapg.com
simjack
Oct 12, 2008 10:24 AM
