tech help L322
Code is Evaporative Purge Valve Output Drive Open Circuit. I would guess the purge valve is bad, or the connector is corroded or loose. Find the hose from the intake to the charcoal canister, and follow it. Purge valve should be there on your model.
Hussain Ashqnani
Aug 22, 2012 01:04 AM
