Sponsored by: CARiD
Terra Firma medium lift TF202 steering issues?
Old Jul 28, 2015 | 07:06 PM
RoverPete's Avatar
Default Terra Firma medium lift TF202 steering issues?
Well its good to be back at the forum. I sold my 1997 disco I a while back and realized i missed it to much. Found a 50th anniversary Disco I with a rebuilt engine and have been back in Rover Heaven/Hell ever since. I recently installed a Terrafirma TF202 lift from AB used the Fathers day sale upon 10% off, great deal. Looks great and rides nice, but it now drives a bit different. I also install a new TF steering dampener. The Rover feels like the front steering is constantly following the contour of the road and moves back to center slowly. I had it aligned twice and is spot on. Also running Stock tire size with recommended tire pressure. One mechanic said the Terrafirma Steering dampener is much stronger than stock and can cause the vehicle to act this way. My dampener attach points are stock and it attached to the rear of the steering linkage. Have any of you guys with lifts had issues like this?
Old Jul 29, 2015 | 12:10 AM
Charlie_V's Avatar
I have a different lift but the problem is almost surely the caster angle. You can get caster corrected radius arms from RTE FAB (they can redo yours) or just adjust to the difference if it isn't too severe.
With a lift, the caster angle (angle of a line between the top and bottom ball joints to the ground) changes. If the change is extreme you can have trouble turning or, the other way, have trouble staying straight. Your lift changes your caster angle so it is harder to stay straight. I have the same issue but I've just adjusted to the twitchy steering and the fact that the steering does not want to return to center on its own.
Old Jul 29, 2015 | 05:45 AM
drowssap's Avatar
I found TF steering damper does not return to center, which can give the truck a completely different feel than the stock.
acg
May 11, 2015 10:20 PM
caymandrew
May 9, 2015 10:05 PM
Rov3r
Sep 17, 2014 11:59 AM
joyntanovich
Aug 31, 2013 10:01 PM
tweakrover
Feb 27, 2011 03:37 PM
