TPMS Module Location L494 2015
Hi Everyone,
I'm trying to locate the TPMS Module on my RRS L494 early 2015 model. I have tried the headliner behind the centre roof console and it is not there. There is a module up there but on closer inspection it appears to be the key less entry module with a completely different connector to the one required. The TPMS has worked since i purchased the car but i would get an intermittent flashing of 'Tyre Pressure Monitoring System Fault' which would flash up for a couple of days at a time and then return to full working capabilities. In the past month or so it has been appearing more and more and now is constantly on. I have tried the boot liner and cannot seem to find it there either. Anyone has any ideas I am open to suggestions to try and find the damn thing.
A garage I took the car to looked into the vehicle reg which suggested the monitor may be somewhere near the drivers door column/footwell but i don't have much faith in this being correct. Any advice is much appriciated.
TIA
TIA
skymast
Range Rover L405 (Fourth Gen)
12-28-2022 01:40 PM
