Sponsored by: CARiD
TPMS Module Location L494 2015
Old Apr 6, 2024 | 02:52 AM
terrieashleigh's Avatar
Red face TPMS Module Location L494 2015
Hi Everyone,
I'm trying to locate the TPMS Module on my RRS L494 early 2015 model. I have tried the headliner behind the centre roof console and it is not there. There is a module up there but on closer inspection it appears to be the key less entry module with a completely different connector to the one required. The TPMS has worked since i purchased the car but i would get an intermittent flashing of 'Tyre Pressure Monitoring System Fault' which would flash up for a couple of days at a time and then return to full working capabilities. In the past month or so it has been appearing more and more and now is constantly on. I have tried the boot liner and cannot seem to find it there either. Anyone has any ideas I am open to suggestions to try and find the damn thing.
A garage I took the car to looked into the vehicle reg which suggested the monitor may be somewhere near the drivers door column/footwell but i don't have much faith in this being correct. Any advice is much appriciated.
TIA
Old Nov 9, 2025 | 05:18 AM
Meg62's Avatar
I'm also interested in this, did you manage to find it? (Also have a 2015 L494)
Thanks
Old Nov 9, 2025 | 09:25 AM
Meg62's Avatar
Thanks. I've checked the boot RHS near the stop-start battery and fuses. That area only had the Body Control Module and the Handbrake Control Module. I'd also checked some other locations but hadn't looked under the seats.
sam4927
Feb 1, 2024 11:43 PM
Pointman0853
Jan 11, 2023 08:03 AM
skymast
Range Rover L405 (Fourth Gen)
Dec 28, 2022 01:40 PM
TASH
Range Rover L322 (3rd Gen)
Sep 29, 2022 08:03 PM
tedjan
Aug 1, 2014 12:04 PM
