Sponsored by: CARiD
Transfer Case Neutral "message"
Old Jan 30, 2008 | 09:39 AM
Bobcat9024's Avatar
Default Transfer Case Neutral "message"
Just purchased a used 2004 Range Rover HSE with 60,000 miles 2 months ago. For the last 3 days I've been getting the message on the dash "Transfer Case Neutral" only blinks on for 2-3 seconds then goes off. Only does this maybe 1 or 2 times on my 30 minute driveto work. Last night on the way home the "Transfer Case Neutral" message came on several time in a row. Then I felt the transmission shift and the dash display said something like "Transmission Safe Mode Program" Once I stopped and turned off the truck everything went back to normal, but when I returned to the highway the same thing happened.
Any help...????? or should I just bring the truck into the dealer and bend over..?!?!?!? )
Thanks,
Bob
Old Jan 30, 2008 | 09:55 AM
Default RE: Transfer Case Neutral "message"
Find a good independent Rover shop and have them scan the system, this is the only way to find and cure the problem.
Old Jan 30, 2008 | 07:32 PM
lrobin3w's Avatar
check your owners manual, and look up the section regarding, towing the vehicle. there is a fuse you can install to safely tow the vehicle without causing damadge to the drivetrain. this fuse may be in place when it should not.
Old Jan 30, 2008 | 08:59 PM
raid13's Avatar
you will get a "transfer case select neutral" when one of the front cv axles
are not in all the way. have you had a front diff replaced lately?
Old Mar 29, 2022 | 03:36 PM
Oberg's Avatar
Default Transfer case neutral
I have a 97 range rover 4.0 SE Drove it no problem pulled in to park it when I put it park it made a grinding noise and then I had no forward or reverse message said transfer case in neutral checked fuse 37 and it checked out any suggestions
Black01D2
Apr 24, 2015 06:55 PM
Discomini
Dec 20, 2014 06:01 PM
RickDaunter
Jul 5, 2013 08:19 AM
lordmorpheus
Jun 13, 2012 05:11 PM
RoverLover
Mar 2, 2006 05:01 PM
