Sponsored by: CARiD
Transmissions
Old Jan 7, 2016 | 10:32 AM
mcabrera3's Avatar
Default Transmissions
So I have a 2003 4.6 hse land rover discovery and u want to swap out the transmission with a 2001 4.0 transmission. Is it compatible?
Old Jan 7, 2016 | 10:34 AM
drowssap's Avatar
i "believe" so but it will be 3/4 inch shorter
Old Jan 7, 2016 | 10:35 AM
mcabrera3's Avatar
I did codes to just swap it out. Can't find the problem and mechanics down here are **** when it comes to landys
Old Jan 7, 2016 | 11:00 AM
drowssap's Avatar
the unit in the 03/04 was slightly beefier than the 00-02 units, but i think it only came out to approx. 3/4 of an inch longer.
i would assume you would be using the 03 drive shaft and cross member. I would check with of of the sites parters to be sure
Old Jan 7, 2016 | 11:02 AM
mcabrera3's Avatar
Hey I got my hand on a 03 buy 4.0 think it'll work?? Mine is a 4.6
Old Jan 7, 2016 | 08:17 PM
chubbs878's Avatar
There were no 4.0 in the 2003. The 2003 and 2004 are nearly identical except for the transfer case. You can exchange anything between these 2 year models. Somebody tell me if I'm wrong
Old Jan 7, 2016 | 08:26 PM
chubbs878's Avatar
search for a transmission from a 2003 OR a 2004. They are very plentiful and no more than $300 for even a low-mileage unit and that price includes shipping.
Old Jan 8, 2016 | 10:03 AM
binvanna's Avatar
Pretty sure the difference is just the torque converter. I think Ashcroft's website has more details.
Old Jan 8, 2016 | 02:10 PM
chubbs878's Avatar
Even minute as that would be, couldn't make a difference.
Old Jan 12, 2016 | 02:15 PM
mcabrera3's Avatar
Hey drowssap so do you think a 02 transmission can work on a 03? Turns out the junkyard owner thought it was a 03 but as I was removing it I was the cdl nipple and I ran the vin and it's a 2003. It's just a little shorter so we can just buy a longer drive shaft???
P.S. thanks a lot man!!
