Sponsored by: CARiD
Trouble code
Old Nov 12, 2007 | 11:31 AM
shearer60's Avatar
6th Gear
Default Trouble code
I asked once and no response. Try again. My abs ,hd, andtc lights on. Instead of driving to dealer I stopped at Advance Auto to see if they could get a code as last time about a month ago I drove down to dealer and was told no faults. Advance auto says a code P1590 came up. Can any of you tell me what that code is pointing to?
2000 Disco 2 102500 miles
Thanks,
Con
Old Nov 12, 2007 | 11:43 AM
Default RE: Trouble code
Can't help you with the 1590 code, it is not on my list. As for the trio of lights, you have to find a shop that has a lap top type scanner like an Auto Logic or Rovers Test Book, they have the ability to read ABS codes. Once you get them, get back to us with their findings prior to doing any repairs. Most find if they get their codes cleared, they usually don't come back.
Old Nov 13, 2007 | 07:05 AM
jyopp's Avatar
I also have a 2000 and have the same thing happen I have my own code reader and find no codes after I shut down the rover the lights go out most of the time and then at random come back I don't know if this is a fault or some thing lose it seams to happen after I apply the breaks going down of up hill any one with any thoughts
Old Nov 13, 2007 | 07:47 AM
Again, engine scanners can't access ABS, SLS or SRS fault codes. Only high end scanners will be able to help.
Matt_Attack352
Jan 13, 2014 09:55 AM
saltyrover
Apr 25, 2013 06:44 PM
sayeedA
Nov 15, 2011 11:02 PM
snugg
May 13, 2008 09:19 PM
dc10freighter
Aug 29, 2007 09:17 AM
