trouble codes
Hello to all,ive got a huge prob with disco,need to get inspected service engine light came on,had scanned 1174,1171,1590,0174,0150,0300,0307,holly crap,replaced both front 02 sensors already clear codes,they return less then 20 miles,cleaned maf sensor with carb clean,off of course,seems like all these codes at one time is odd,leaning towards replacing MAF,any help will be appreciated.
First, the carb cleaner, which you never use on a MAF, will kill it.
The front 02 is dead which is causing you a lot of grief and your 1590 is a rough road/ABS fault code.
Check and make sure your 02 sensors connections are oil free, if they are contact whoever you bought the 02's from and get it warrantied.
Yep,good advise on valve cvr gasket,was loose went back to auto zone confirmed again with scanner bank 2 sensor one,gonna put old one back in get new one under warranty,bank 2 sensor one is passide front before cat,opposite side on cylinder 1 ?
well,went back to auto zone changed out bank 2 sensor 1 have driven 35 miles no light,will try again driving tomorrow,auto zone has no clue had 10 codes,if wasn't for you guys,would have spent a ton.thanks will try again tomorrow
