Sponsored by: CARiD
tune up ideas please
Old Jan 24, 2013 | 08:24 AM
bgeezas400's Avatar
6th Gear
Default tune up ideas please
Ok I'm a newb so bare with me but I'm about to buy a 1997 land rover disco with 140, 000 miles on it and I was wondering what are some things I probably need to fix or tune up, any advice would be much appreciated
Old Jan 24, 2013 | 09:15 AM
greenharoguy's Avatar
Whats up with all the other quotes in your post?
Old Jan 24, 2013 | 09:24 AM
antichrist's Avatar
Is it a 5-speed or automatic?
Is it new to you? If not, what have you recently done to it, like in the past year?
Old Jan 24, 2013 | 09:34 AM
Michael M. Koch's Avatar
Any known issues? Deal with those first, obviously. Get ready for lots of hands-on work, and invest in some metric tools if you don't already have a set.
Welcome, and good luck!
Old Jan 24, 2013 | 10:55 AM
bgeezas400's Avatar
6th Gear
Automatic and I'm buying it this weekend
Old Jan 24, 2013 | 10:56 AM
bgeezas400's Avatar
6th Gear
Anti lock brake light and catalytic converters are gutted
Old Jan 24, 2013 | 11:16 AM
bgeezas400's Avatar
6th Gear
Old Jan 24, 2013 | 11:18 AM
bgeezas400's Avatar
6th Gear
Auto and I'm buying it this weekend
Old Jan 24, 2013 | 11:47 AM
binvanna's Avatar
The ABS and cats are not a problem as long as you don't have to pass a test. Were the head gaskets done? If not, I would expect to do that and price accordingly. You might be able to do the job yourself and save labor, but it's worth about $2k on the price either way. They may not leak now, but if they haven't been changed, the probably will as they just don't last that long on these motors.
Rust is probably the big thing to check for.
After that, you want the radiator in good condition.\
Check the state and age of the battery
Plan on replacing all the rubber coolant hoses
Plan on replacing the oil and transmission cooler lines (these are pricey)
Look for steering box leaks and check the steering wheel shaft and pitman arm for any loosness. The steering box can be tightened up.
Plan on replacing the wheel bearings. If you don't do that right away, at least check them for looseness and tighten the nuts.
check the brake pads
clean the MAF (do this very carefully and research the procedure because they're pricey)
check the driveshafts and grease
see how much the swivel ***** (cv joints) are leaking, drain the fluid and consider replacing with cv grease or re-doing the seals
Mike's list is a good run-down but personally I don't use any of the additives, stop-leaks, or miracle products, just the factory recommended fluids
Old Jan 24, 2013 | 11:55 AM
binvanna's Avatar
tie rod ends, bet the boots are cracked and the rod ends are gone, need new ones, hope the adjuster sleeve isn't seized
figure the shocks are gone too
