Sponsored by: CARiD
tune up ideas please
Old Jan 24, 2013 | 11:58 AM
binvanna's Avatar
check the condition of the rubber bushings; they can last a long time on the road but go fast off-road or if they have fluid leaking onto and damaging the rubber. The panhard rod and lower radius arm bushings go the fastest.
not sure if the 97 has a rotoflex on the driveshaft but I'd plan on fixing that if its there
Old Jan 24, 2013 | 12:03 PM
binvanna's Avatar
not really tune-up but check the function of the door locks and window regulators and also the door seals
The window regulators have a plastic wheel that fails and you'll know when the window doesn't go down smoothly and quietly; check all the windows all the way
look for damaged window seals and door seals the rubber stripping on back is often cracked, and the inner door seals often get damaged and they cost a lot (about 100 bucks per door last time I checked)
Old Jan 24, 2013 | 12:44 PM
bgeezas400's Avatar
6th Gear
Thanks man and yea 2 windows are messed up
Old Jan 24, 2013 | 01:14 PM
binvanna's Avatar
new regulators are $100 each; some people try to replace the plastic wheel only with a screen door part from the hardware store but you have to rig it a little, there's an article in the tech section I think
Old Jan 24, 2013 | 03:09 PM
Reprint of my original reply, not sure what got drug in with my original reply.
If you just bought it, you will need more then a tune up. Here is my list of suggestions. if you have any questions, get back to me.
1 Oil filter, K&N 3001 or Mobil 1- 301
1 Factory air filter
6 Qts. of engine oil
2 feet of 3/16th vacuum tube
2 feet of 5/16th vacuum tube
6 Qts. Of Vavoline’s high mileage Dextron 3 ATF
7 Qts. of 80/90W synthetic gear oil, 85W/140 for HD use
3 Pints of Vavoline’s DOT 4 Brake fluid
4 Qts of synthetic ATF fluid
1 bottle of Lucas P/S stop leak
1 bottle Lucas Tranny Stop Leak
2 Gallons of Peak or any green or yellow coolant, don’t use Dexcool
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platinum Plus 4's
1 Set of Magnacor or STI 8mm plug wires
1 Serpentine belt
2 Bottles of SeaFoam gas additive
1 T/Stat
1 bottle of WaterWetter or Purple Ice
1 new fuel filter
Hoses and belts, as necessary
Front and rear wheel bearings and all seals for wheel bearings and swivels if necessary
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive, change the filter if necessary
Change the coolant and t/stat
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Repack or replace the 4 wheel bearings
Service the swivel *****, reseal, refill and adjust the pre-load
Replace the fuel filter
Inspect and replace all hoses, brake, coolant and cooler lines as necessary
DreMal
Sep 10, 2023 05:06 PM
tigertrakstar1
Mar 5, 2014 04:13 PM
KGN96discoSE7
Jan 2, 2011 06:44 PM
llPANCHOll
May 24, 2009 09:08 PM
My first Disco
Dec 10, 2006 05:04 PM
