Sponsored by: CARiD
V-Belt Power steering conversion question
Old Nov 1, 2014 | 09:25 AM
Shiftonthefly1's Avatar
Default V-Belt Power steering conversion question
I've read the thread on using the chevy power steering pump instead of the factory one. But in all those threads it seems to be a serpentine belt pump that's being replaced. Does anyone know if the same mod works on a 3.9 w the V belt set up? I'm worried about the pulley and the alignment of the belt too. Can I use my original pulley no problem?
I'm aware the distributor is in the way of the required 90 degree fitting. I'm hoping to work around that by using a molded 90 hose.
For the record who ever designed this p/s bracket set up should be back handed. I was going to modify the bracket in hopes of being able to get a 1/4 socket from the front on the ridiculous nut behind the distributor. Maybe notch it a bit?
Some one used the actual pump to tighten the belt thus ruining the pump precisely the way it says not to in the manual.
Old Nov 6, 2014 | 04:19 PM
No one has done the chevy pump mod on a v-belt truck?
Disco Mike
Sep 20, 2024 01:23 PM
gundog
Sep 22, 2019 10:37 PM
ogden45
Dec 28, 2011 08:50 AM
JakeVT
Oct 15, 2011 03:03 PM
PDXDisco
Jun 8, 2008 09:39 AM
