Sponsored by: CARiD
vibration on exceleration
Old Mar 29, 2010 | 10:01 AM
Mahan's Avatar
4th Gear
Default vibration on exceleration
I have bad vibration on exceleration. My 1st guess is that rubber joint on my rear driveline. Any other ideas?
Old Mar 29, 2010 | 10:07 AM
Mahan's Avatar
4th Gear
Default more info
I have a 2002 Discovery.
Old Mar 29, 2010 | 12:15 PM
hilltoppersx's Avatar
stop driving your truck. has the front drive shaft been rebuilt with greasable u joints? whats the mileage on your truck?
Old Mar 29, 2010 | 12:52 PM
Mahan's Avatar
4th Gear
Default 2002 discovery
about 120,000 and no the front drive line has not been rebuilt yet. I am going to look at it today.
Old Mar 29, 2010 | 03:39 PM
AAP's Avatar
AAP
I don't know that there is anything to look at. If it hasn't been rebuilt, it should be, even without signs of imminent failure. It may give without warning and cause you a world of problems.
Old Mar 29, 2010 | 05:59 PM
Mahan's Avatar
4th Gear
Default Problem Fixed
Replaced front driveline with custom built one from Drive Line Services in Sparks Nevada. Works great for 375.00...
Old Mar 29, 2010 | 06:00 PM
green machine's Avatar
I agree with AAP replace your front u with a greasable one. From the horror stories on here and the web, you are overdue on a Disco 2. Check over all the U joints and couplers including the fasteners. Check powertrain mounts as well to eliminate other common causes.
Old Mar 30, 2010 | 08:04 AM
rebuild your drive shaft now. or pay dearly later
Old Apr 2, 2010 | 09:41 PM
CANAMDiscovery's Avatar
Had the same vibration and had my FRONT drive shaft changed just in time. Mine was very bad and noticeable if you can get a look at it. If you have a place where you can get under and look at the joint it should be obvious. The joint on mine looked like it was about to fall apart.
Drive it slowly or not at all until you get a part if you find this is the issue.
I heard that if it lets go at any significant speed...possible good bye transmission!!! $$$$
Old Apr 11, 2010 | 01:00 PM
kylesullada's Avatar
I think I have the same problem as you. I haven't drivin my disco II since the problem accured, except for up and down my street, going 10 mph to guess what could be happening. When I did so it felt as if something was trying to lock up in my driveshaft. Where should I begin to fix my problem?
