Sponsored by: CARiD
Water Leaks... could do without the rust!!
Old May 22, 2005 | 04:56 PM
bmwrovers's Avatar
Default Water Leaks... could do without the rust!!
Does anyone have any advice about a water leak in the back of my '96 Disco? I have replaced all the rear window seals and the alpine window seals (not a fun job), but i'm still getting water coming in some where!!! i'm getting tired of stripping the interior and drying it all out/ replacing seals... everytime i "troubleshoot" it with my hose i can't find any leaks, but the next time it rains... walla ... water leakage!
Any Ideas?
Old May 23, 2005 | 01:05 AM
jasonsLR's Avatar
Default RE: Water Leaks... could do without the rust!!
Are you sure it is from the rain.
I had a simular problem, water was coming out of my lower vents, take a look at "water on floor" post under discovery section.
I had water all over the front and back from this, of course it leaked more with the A/C on high
I first thought it was from the rain but it was the rainy season when it started to happen. after i clean out the rubber gromet drains it fixed the problem.
Let us know
later
Old May 23, 2005 | 02:09 AM
Bene's Avatar
i could be coming up from the floor. we had that problem with the box truck at work. some sort of caulking stuff took care of it.
Old May 23, 2005 | 01:02 PM
mikemeyer0's Avatar
check the gasket around the fuel pump access plate water seeps there then absorbs into the carpet.
Spencerfitch
Sep 27, 2020 12:17 PM
FlyingZebra34
Apr 22, 2013 12:07 AM
discoboy
Dec 20, 2012 02:24 AM
JPSpen
Dec 1, 2012 08:09 AM
dinandan
Jun 22, 2006 07:22 PM
