Sponsored by: CARiD
Water pump replacement advice
Old Aug 13, 2010 | 08:07 AM
West Slope Rover's Avatar
5th Gear
Default Water pump replacement advice
This is my first post other than my introduction. I'm about to replace the water pump on my 1993 County with the 4.2 under the hood. It all seems straight forward enough, but I thought that I might ask those in the know if there are any things to be aware of peculiar to this vehicle.
I'm aware that the threads on the big fan nut are reverse threaded (just give the wrench a good whack with a hammer in the proper direction while the belts are still attached, correct?)
Anything else that I should know before I begin? I must admit that I love the car, I'm a bit intimidated by the mechanics of this beast after reading about it on the interweb! Thanbks in advance for any help given. Hopefully, someday I can be the one helping with advice.
Old Aug 19, 2010 | 06:51 PM
baetis99's Avatar
4wd High
Download the RAVE and you should have no problems. Search this site for RAVE download. Make sure you get the gasket as well as the pump. Fairly straight forward job. I would switch out the thermostat while you're at it.
Old Aug 20, 2010 | 07:19 AM
5th Gear
Thank you kindly for the help. The RAVE seems like a must have.
j.dstasio
Mar 24, 2013 08:11 PM
rover newb
Apr 24, 2011 08:05 PM
West Slope Rover
Aug 14, 2010 08:07 AM
Jawbox
Mar 10, 2009 07:29 PM
bigugly82
Mar 27, 2008 04:12 PM
