Wet Carpet???
I just bought a 01 Range Rover, and the drivers side carpet seems to get very wet. What could be the cause of this, im thinking it has something to do with the A/C condensate drainage. Any help would be great.
Somehow you could have a little rust in your floor, that could cause you to get soaked especially if your tires are spitting water up. I have heard of a common problems with Camaros with the AC causing the passenger side to get soaked but I cant remember a single bit of it.
the a/c condenser drain line might stopped up. try to check it. you may use pencil or other blunt obeject to clear it out.
bcolins
Jun 29, 2015 07:22 PM
NWDiscoRover2004
Aug 7, 2007 01:01 PM
