Sponsored by: CARiD
Wet Carpet???
Old Aug 22, 2005 | 03:03 PM
drpenaranda's Avatar
6th Gear
Default Wet Carpet???
I just bought a 01 Range Rover, and the drivers side carpet seems to get very wet. What could be the cause of this, im thinking it has something to do with the A/C condensate drainage. Any help would be great.
Old Aug 22, 2005 | 05:28 PM
Lebowski87's Avatar
Default RE: Wet Carpet???
Somehow you could have a little rust in your floor, that could cause you to get soaked especially if your tires are spitting water up. I have heard of a common problems with Camaros with the AC causing the passenger side to get soaked but I cant remember a single bit of it.
Old Aug 22, 2005 | 10:55 PM
fancy's Avatar
3rd Gear
you can find this fix and many other here
http://www.rangerovers.net/
good luck
Old Aug 30, 2005 | 10:03 PM
LrTECH's Avatar
you will need to unclog your a/c drains which are under your vehicle on each side of the tranny. You will need a flashlight and something long and point to clear them.
Old Oct 7, 2005 | 09:35 PM
rinmud's Avatar
Look I dont want to insult anyone but has anyone thought 2001 range and heater core "O" rings ?????????????????????????????????????????????????? ??????
Old Oct 19, 2005 | 12:54 AM
duboff's Avatar
if it is water, check the a/c drainage. If it is coolant, then check the heater core, connections and seals. hope it helps. gotta love a rover. duboff.
Old Oct 25, 2005 | 10:19 PM
kylle08's Avatar
the a/c condenser drain line might stopped up. try to check it. you may use pencil or other blunt obeject to clear it out.
landbeater
Jun 18, 2008 09:05 PM
zerochills
Jan 11, 2008 06:24 AM
ajh
Aug 17, 2007 10:33 AM
NWDiscoRover2004
Aug 7, 2007 01:01 PM
