What in the world have I done now...
Ok so on my 2000 4.0 Disco I upgraded to Magnacor 8mm wires and while I was in there I replaced the valve cover gaskets and cleaned the IAC, as I did so the Iac would make a noise like something was moving freely. It didn't seem to do that before I cleaned it. For some reason the truck will not start (and yes I hooked the wires back up correctly). there were several threads on proper wire diagrams for the coil and firing order as well as consulting my RAVE book. There is now a buzzing, vibration coming from my IAC while the key is on, like a pump that is locked up. It does crank and will try to start for a few seconds while first cranking, but then just cranks. If I disconnect the IAC from the intake it sounds like a back fire through the intake, popping but not loud. Could someone please give me a hard time for doing something wrong. Thanks!!
Thanks in advance dougwrench55, for your assistance. I used carb and choke cleaner on the IAC, and was using a schematic from a thread somewhere. I really would have thought my RAVE book would have had one, but no. I found a schematic that explained that it should be viewed from inside of the cab, so switched the plugs on the coil around a viola it started. I was hoping that would have fixed my idle issues, but it still idles a little rough and always idles a little more rough after acceleration. I need to get my codes read again, since the light came back on after resetting after the wires and new O2 sensors. I'm leaning toward the MAF or I did jack up my IAC. Oh well....
clang
11-12-2015 12:17 PM
