Sponsored by: CARiD
White smoke but no sweet smell
Old Apr 26, 2017 | 06:07 PM
Birdperson's Avatar
6th Gear
Default White smoke but no sweet smell
I'm a new owner of a 2002 disco 2, 93k mi, and I've been spending the past two weeks doing a major tune up. So far so good, however my latest issue has me concerned. The previous owner claimed to have just had the head gasket replaced and upon my initial inspection before purchasing all seemed fine. No smoke, oil good, coolant etc. Now ive driven her a couple hundred miles and I've got white smoke, water and soot spitting from exhaust, however, no sweet coolant smell. It had the dash waterfall sound until I filled and bled the coolant properly today. Any thoughts? O2 sensor? Running rich? God I hope its not the gasket.
Old Apr 27, 2017 | 07:08 AM
WaltNYC's Avatar
Are you losing/consuming coolant? Now that you've bled the system take note.
Generally, if you have a blown HG, exhaust gases will be mixing with the coolant. Your local autoparts store will likely have a test kit for this.
Old Apr 27, 2017 | 06:48 PM
Birdperson's Avatar
6th Gear
Yep, seems like its drinking coolant faster than ever now and I believe I smell a faint scent of fuel in in the reservoir. I had also changed the plugs which had resolved the misfire issue I was having but it seems to have returned. About to inspect them now. Ill bet that's where at least one of the gasket failures is.
twin6
Feb 19, 2017 02:16 PM
Aferrell71
Jan 3, 2012 02:19 PM
Rearden Steel
Oct 31, 2011 09:22 PM
losinov
Mar 14, 2011 10:42 AM
tsuami1
Jul 15, 2009 02:28 AM
