Sponsored by: CARiD
Window Regulator
Old Mar 5, 2008 | 12:03 PM
MgnFicnT's Avatar
Default Window Regulator
As i rolled my window down last night in the drive through, i heard a series of cracks before my window dropped conviently into the door. After further inspection and taking the door panel off i discovered that the C shaped piece with the gear teeth was laying on the bottom of the door. Nothing appears to be cracked and the motor still runs, would it be possible that a screw just might have come loose and needs to be replaced or should i just order a whole new regulator.
Old Apr 2, 2008 | 11:15 AM
firebell's Avatar
Default RE: Window Regulator
You will need to order a new regulator, to save $ go to Roverland.com They are about $80 compared to $180 at the dealer.
RedAustinIX
Aug 10, 2020 11:43 PM
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
jw928
Feb 6, 2010 06:51 PM
garover
Mar 28, 2005 08:44 PM
