Ive just bought a 96 discovery and the only window that works is the front passenger, ive heard there is a box in the glove box which might be the problem, any thoughts?
the window lift ecu suffers from poor or broken solder joints.....you can remove it an attempt to repair the bad points...or...perform the window lift bypass....search a little here for that....
