Replacing front muffler
Some systems had a donut in that flange, but I don't think yours does. Replace the rubber hangers because when they fail, that's what cracks the pipes. It looks like rust did all the work, but I bet there was broken hangers and a lot of the cracking was because of the vibration and stress from unsupported pipes.
If you can get those nuts off, you can re-use that flange. I ended up having to drill/tap the bolts out and replaced them with regular bolts.
The best way to cut the pipes is with an exhaust pipe cutter. It's way better that bending and busting sawzall blades.
The best way to cut the pipes is with an exhaust pipe cutter. Amazon.com: KD Tools KDS-2031 Exhaust and Tailpipe Cutter: Home Improvement It's way better that bending and busting sawzall blades.
Thanks! I was hoping to re-use them, but I guess if I cant I can just go get some new ones. I'm hoping all the hangers are okay, because I just got the muffler and flanges.
Spray lube the hangers they will come off easier, d1 has bolt flange in front of muffler uses flat gasket and part of the over axle pipe attached at rear of muffler, if the muffler looks like that save time and replace it all cause the rest won't be far behind, when the over axle pipe rotted on mine it rotted on the seam which faces up at the body and fills the cabin with exhaust, looked great from the bottom
Iirc d2 muffler has flat flange front and back, your sign says you have a d1?
