Johnson Rods Land Rover Lift Kits and Wheels
Defender lift kit
Old Jul 16, 2020 | 01:44 PM
Johnson Rods's Avatar
LR Forum Vendor
Default Defender lift kit
Check out our new Defender lift kit: New Defender Lift Kit
Follow us on Instagram: @johnsonrods
Many Land Rover dealers use our lift in their showrooms as an upgrade package. Our lift is preferred because of the quality of construction and materials that can stand up to extreme hot and cold conditions without breaking down. We use 3/16 high quality stainless steel which provides strength and durability. Our rubber attachment points are military spec. grade, extra thick just like the original Land Rover part which insures a tight non slip connection and which makes them less susceptible to cracking and breaking down under harsh conditions. In fact, the rubber has a high resilience and tensile strength, abrasion resistance and operates effectively in temperatures between -60 degrees F to 180 degrees F.
With our 1.5 inch Defender lift kit you can fit 275-60-20 - 33 inch tires as show below with this dealer installed Johnson Rod lift. Ask your Land Rover dealer to install Johnson Rods.
Check out our links in the signature below and follow us on Instagram to get the latest update on Defender builds.
1.5 inch lift with 275-60-20 BFG KO2
__________________
Please visit our website: https://www.Johnsonrods.com
Visit our vendor section:Johnson Rods Vendor
Old Oct 7, 2020 | 04:48 PM
LR Forum Vendor
Another great dealer build using our 1.5 inch Johnson Rod lift with RR Sport SVR wheels
285-45-22
Ask your Land Rover dealer to install Johnson Rods with an upgraded package.
Dealer build with 1.5 Johnson Rod lift RR Sport SVR wheels 305-45-22
__________________
Old Oct 7, 2020 | 04:49 PM
LR Forum Vendor
Got to love this Defender X with Johnson Rods and 285-45-22.
Very common to put on 275-60-20 33" as well.
Dealer installed Johnson Rods
285-45-22
__________________
Old Oct 7, 2020 | 04:51 PM
LR Forum Vendor
__________________
LR Forum Vendor
__________________
Old Oct 7, 2020 | 04:52 PM
LR Forum Vendor
__________________
Old Oct 7, 2020 | 04:53 PM
LR Forum Vendor
__________________
Old Oct 7, 2020 | 04:54 PM
LR Forum Vendor
__________________
Old Oct 7, 2020 | 04:55 PM
LR Forum Vendor
__________________
LR Forum Vendor
__________________
