18" LR2 Se bolt pattern
RE: 18" LR2 Se bolt pattern
its true, they have the same bolt pattern as most jags, which is different the rovers, however, jag wheels have a different hub center size so they dont fit either... rover does offer what i think is a nice rim for the lr2, its a black chrome 19 inch, comes standard on the hse and was a option on the se, take a look at it, see what you think, i dont think there are too many options for this wheel out there, and if you do find one, make sure the hub size is right too, theyre hub-centric, this is very important
...As you both already mentioned the bolt pattern is not the same, 5x108 on the lr2, 5x120 on the RRS. However, I have talked to some very knowledgable people about using hub adapters that would allow you to run the Stromer wheel, or any different bolt pattern for that matter. It's not cheap though, the hub-centric adapters run about 80 bucks a piece.
