18" LR2 Se bolt pattern
Old Jun 20, 2008 | 01:25 PM
DocSean's Avatar
4wd High
Default 18" LR2 Se bolt pattern
I'm looking at the 20" stormer wheels that came on the supercharged range rover (if I decide to buy a gently used lr2) my question is if anyone can tell me what in the world the bolt pattern is for the LR2 so that I can figure out if they are interchangeable.
Sean
Old Jun 20, 2008 | 11:06 PM
jenin5280's Avatar
Default RE: 18" LR2 Se bolt pattern
They aren't. I saw some awesome Redbourne wheels on a super sport that were customized with the Land Rover emblem on the wheel. I tracked them down only to find out they only Rover they don't fit is the LR2. They have a completely different bolt pattern.
Old Jun 21, 2008 | 11:59 AM
roverguy7's Avatar
its true, they have the same bolt pattern as most jags, which is different the rovers, however, jag wheels have a different hub center size so they dont fit either... rover does offer what i think is a nice rim for the lr2, its a black chrome 19 inch, comes standard on the hse and was a option on the se, take a look at it, see what you think, i dont think there are too many options for this wheel out there, and if you do find one, make sure the hub size is right too, theyre hub-centric, this is very important
Old Jun 23, 2008 | 12:45 AM
DocSean's Avatar
4wd High
...As you both already mentioned the bolt pattern is not the same, 5x108 on the lr2, 5x120 on the RRS. However, I have talked to some very knowledgable people about using hub adapters that would allow you to run the Stromer wheel, or any different bolt pattern for that matter. It's not cheap though, the hub-centric adapters run about 80 bucks a piece.
Old Aug 22, 2008 | 03:23 PM
fsufan's Avatar
4wd High
the answer is 5 on 120 with at least a +38 offset. if your looking for rims look at most front wheel drive patterns, they are usually the ones to best fit your needs. check out pdkwheeels.com or call them.Ask for aaron unger.
TraV300
Apr 29, 2007 11:01 AM
groundpounder
Oct 13, 2006 06:28 PM
pwag
Jul 23, 2006 11:14 PM
surfrover
Apr 18, 2006 04:12 AM
sclarkie
Aug 9, 2005 04:01 PM
