2009 land rover LR2
Old Apr 12, 2024 | 07:30 PM
Jerry T's Avatar
3rd Gear
Question 2009 land rover LR2
so my 2009 LR2 is stuck on heat, i turn it to ac and it still blows heat out the floor and dash vents, and when i turn it to face vents it doesn't do anything. i have already checked the fuses and relays with no luck. any ideas?
Old Apr 13, 2024 | 10:47 AM
ThorInc's Avatar
Actuator blend door is likely stuck, can try to reset the system with software that is connected through OBDII port or go to freel2.com , LR2 and FL2 are sisters but for engine and transmission depending on year class or model. Search for blend door actuator stuck
Old Apr 14, 2024 | 03:23 PM
Jerry T's Avatar
3rd Gear
thank you i will look into that
Old Apr 14, 2024 | 08:12 PM
flybd5's Avatar
The heater blender is attached to the fan housing under the passenger side, behind the glove compartment. It maybe be a little hard to get to but may just be stock or the connector came loose.
Nicholas Impellizzeri
Jun 9, 2019 04:48 PM
roverreitzel7
LR2
Feb 27, 2013 09:51 AM
scarrittjd
LR2
Dec 5, 2007 05:42 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
