2011 Land Rover LR2 Won’t Start
Old 09-24-2021 | 03:13 PM
flybd5's Avatar
Originally Posted by SlimGoody
I’ll have to get someone to take a look at it. Thank you
What is that orange stuff on the battery terminal?
SlimGoody (09-25-2021)
Old 09-24-2021 | 07:01 PM
SlimGoody's Avatar
Originally Posted by flybd5
A faulty starter will absolutely drain your battery. If you don't fix it it can drain it to the point of making the battery unusable.
‘I have no idea, I didn’t post that picture.
ThorInc (09-24-2021)
Old 09-24-2021 | 09:10 PM
p_gill's Avatar
Connections
1 B+ (Positive terminal of the Battery) on the LR2 this is covered by a plastic cap
2 Solenoid
3 Switched B+ When the Solenoid is activated terminal 3 injects over 100 Amps to the battery thru the braded copper wire
How it works
a) A voltage is applied to #2 and a current of about 30 Amps is injected
b) The Solenoid moves the starter gear to Engauge with the flywheel
c) Connection #1 and #2 are joined together and the starter motor starts spinning and about 300 Amps are injected (this happens at the same time as the previous step)
d) Engine starts, solenoid is disconnected from the Voltage at #2 and a spring returns it to the rest position which disconnects #1 and #3
This is for a Bosch Starter, if your starter has been replaced it may not have the copper braded wire.
If you want to know why Bosh didn't use a more typical insulated stranded wire you will need to ask them
The next time you change you oil take a look and you will see something very similar
Note: it is possible that BOSCH found it easier to just braid the wires used for the motor winding
I've never made starter motors so I can't say for certain
Old 09-24-2021 | 11:18 PM
LR2driver's Avatar
I’ll try to find it and give it a little hit🤷‍♀️Thank you so much ☺️
If you give it a whack, aim for the solenoid, not the starter housing.
Old 09-25-2021 | 11:38 AM
merlinj79's Avatar
That's the small cylinder. The one that does NOT have a sticker saying "Do Not Strike with Hammer"
Old 09-25-2021 | 11:41 AM
merlinj79's Avatar
My code reader said abnormal battery so I purchased another battery and my truck still won’t crank. Now I have to return this battery. I tried the code reader on the new battery and it says the same thing abnormal battery. I’m going to try the reset next, because I have no idea what the issue is. However my brake is not pressing down either. Thank you guys do much. This is so frustrating
The brakes are fine, there's just no boost vacuum since the engine won't start. They still work, just have to press much harder. They'll return to normal after the engine starts.
Old 09-25-2021 | 11:51 AM
SlimGoody's Avatar
I’m about to go outside and try that now. The smaller cylinder with the 3 screws😉 Thank you so much ☺️
Old 09-25-2021 | 12:19 PM
SlimGoody's Avatar
It didn’t work so I feel that the starter is completely dead.
Old 09-25-2021 | 01:33 PM
p_gill's Avatar
Slim,
Based on your posts I thought you were having someone else do the work.
If you are doing it then Verify that you have 12 volts at location #1 (you will need to pry off the plastic cap.
Be careful this is connected directly to Battery + which is why it has a cap.
Plastic tools would be a good choice for this if you haven't replaced a starter before. (I am only talking about removing the cap to expose #1)
Assuming that you have 12 Volts the next step is to check Pin #2 it should be 0V and if a helper presses the start button then it should go the 12 Volts.
If you pass both tests then replace the starter.
Let us know
Thanks
Paul
Old 09-25-2021 | 02:00 PM
SlimGoody's Avatar
Originally Posted by p_gill
Slim,
Let us know
Thanks
Paul
Hey Paul, I had someone whack it for me. However, nothing seems to be working but I feel it’s definitely the starter so Monday morning it’s going to the shop. When I try to crank it now I hear a little click noise.
Quick Reply: 2011 Land Rover LR2 Won’t Start
