2011 LR2 High Center Brake Light
Old Jan 3, 2021 | 01:37 PM
flyer08's Avatar
Default 2011 LR2 High Center Brake Light
2011 LR2 High Center Brake Light socket (bulb holder) needed.
Anyone know where this part can be bought or part number? No need for entire light assembly, just socket with pig-tail
Thanks
Old Jan 3, 2021 | 07:05 PM
flybd5's Avatar
Thanks
If you know the bulb type all you need is to search for "<bulb_type> socket" and off you go. eBay probably has it.
Old Jan 3, 2021 | 09:56 PM
flyer08's Avatar
Have bulb. Tried all kinds of search but no go. Bulb is a 921, I think. Can only find entire assembly for light. Socket is a quarter turn to release from bracket with a approx 4in wire that plugs into power source. Seems Land Rove should make separate part but unable to locate anything. Hate to spend $70 to $130 (OEM) on the assembly, bracket, socket, and lens. Should be a $7 part
Can find a socket with pigtail, but wil; have to attach the part that plugs into LR2 power. Hate add a possible additional failure point plus then very different than OEM.
Old Jan 4, 2021 | 09:20 AM
flybd5's Avatar
https://www.superbrightleds.com/cat/...921194,1,3995:
Old May 27, 2022 | 07:11 AM
hotrod46's Avatar
6th Gear
Default Shout out
Shout out to Flybd5 for the tremendous help you have been to me on this site.
Working through the HDC fault thing on my LR2 and debating replacing wheel bearing on the Boxster.
Retired nearly 10 years I am busier than ever.
Thank you
Bob Palitz
LR2
Dec 9, 2019 05:53 PM
kind16
LR2
Sep 15, 2019 01:00 PM
dagger987
LR2
Feb 18, 2015 10:08 AM
nickcos2003
LR2
Nov 13, 2010 06:03 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
