2012 LR2 HSE cranks but doesn't start
Old Sep 22, 2023 | 03:48 PM
Lr22012lol's Avatar
4wd High
Default 2012 LR2 HSE cranks but doesn't start
I went to go get some gas last night & after I dinished I turned on my LR2 & put it in Drive but before I could even get drive out the parking spot, it shut off. It had a similar issue a few months & I remedied it by replacing the fuse for the starter (F22 front passenger compartment) & did it yesterday morning as well however I just replaced the fuse and it did the trick up until later yesterday. I got it towed home & I went to go try a new fuse but it didn't work. It turns on and everything, ac radio all work but it just doesn't turn completely over.
Old Sep 23, 2023 | 01:19 PM
merlinj79's Avatar
Fuse was blowing for a reason, so that needs to be addressed. A bad starter could well blow the fuse, and if it's a 2012 that has never had the starter replaced it's probably about time.
Use a scantool to check for codes, but if that doesn't shed any light the obvious thing to do would be a new starter.
But I would check the connections to the starter first, and any big ground straps you can find.
Tommylr22013
LR2
15
Dec 9, 2023 02:51 PM
Mark P
LR2
Oct 30, 2021 12:28 PM
Jerry T
Sep 24, 2021 07:02 AM
Daniel Ortman
Mar 15, 2018 07:35 PM
LR2driver
LR2
Dec 16, 2015 02:00 PM
