2014 LR2 OBD P0303 P1315 Cyl#3 Coil Replaced
Old Feb 9, 2020 | 03:17 PM
flyingscot's Avatar
Default 2014 LR2 OBD P0303 P1315 Cyl#3 Coil Replaced
Intermittent misfire - car in 'reduced performance' mode. After discussion with Landy specialist mechanic, changed the coil on cylinder 3 (ref P0303) - $30
Amazon Amazon
Simple enough job - you tube video for evoque (same engine) -
So far so good. Fingers crossed this is the issue. I'll update the thread if any further complications.
Old Feb 9, 2020 | 04:28 PM
flybd5's Avatar
Lucky for you you got something other than a plain P0300. When I see the plain one I turn around and flee.
Old Feb 13, 2020 | 07:28 PM
Jade Dockery's Avatar
Default 08 lr2 se
I had the same codes right after changing my spark plugs. Come to find out I had a bad ground wire that was coming from the fuel rail I presume? it caused mine to misfire then no start. I taped the exposed wire and adjusted the ground and everything went away.
Old Feb 13, 2020 | 07:47 PM
flyingscot's Avatar
Thx Jade - yep this was the kind of info I was seeking..... in the event the coil replacement does not do the trick......
Sales@lk8parts.com
Build Threads
Jan 18, 2020 07:22 AM
bornhandy
LR2
Oct 13, 2019 11:06 PM
LR2driver
LR2
Oct 6, 2017 12:01 AM
jrb222
LR2
Sep 11, 2008 01:12 AM
Land_Man
Sights N Sounds
Aug 25, 2007 02:29 PM
