4 amigos on after diff replacement
I just replaced the rear diff and both rear struts on my 2008 LR2.
had struts right off the car along with both rear shafts.
While I had it apart I resealed the Haldex unit but could not get the electric pump out of the housing.
I tried to tap it out and even used a very small amount of heat with a propane torch but it still wouldn't come out.
I went to start the vehicle and pressed brake pedal almost went to floor as I had calipers off.
I noticed the 4 amigos came on. Any ideas on what may have happened?
From what I read could be brake light switch or I could have damaged the electorc motor on the haldex.
Fix one problem created another- ARRRRG.........oh yeah nothing but fun just when you think you fixed one problem....
LewKrehnbrink
Oct 6, 2011 01:42 PM
