AC losing charge - 2008 LR2
Old Sep 15, 2023 | 01:07 PM
OvalPiston's Avatar
7th Gear
Default AC losing charge - 2008 LR2
It takes about 2 weeks for my AC system to lose its charge and start blowing hot air. I had it drained, recharged, and a dye added. Can't find any leaks in the engine compartment. I had a new compressor put in two years ago.
Where else should I be looking? And do the evaporators go bad?
Old Sep 15, 2023 | 04:26 PM
p_gill's Avatar
Look at the Valve core for the high side and the low side.
Amazon Amazon
I replaced mine due to a slow leak.
Are you using a BLACK-LIGHT to find the DYE?
Didn't the AC shop check for leaks?
Good luck
Paul
Old Sep 15, 2023 | 04:45 PM
merlinj79's Avatar
The shop should have replaced the valve cores, but if they didn't for some reason then they will probably leak if original.
You should be able to see dye (yes you need a UV light lol). If you can't find any with UV, then it might be the core in the cabin. I assume that's not very accessible
Old Sep 16, 2023 | 04:02 PM
ThorInc's Avatar
Both my AC leaks were valve cores, first time I got a shop to replace it....that lasted one season, not sure what they actually did. Second time, I bought the cores and tool kit, took it to a friend with a body shop and the right equipment, he drained the system, I replaced the core myself and he filled it up......two seasons now, nice and cold.
Old Sep 17, 2023 | 05:38 PM
flybd5's Avatar
My shop found a leak where a dye would still be difficult to find, in a pinhole on the tube to the evaporator. It's behind the instrument panel but my mechanic was able to get to it without pulling it.
BitLoud
LR2
Jul 17, 2020 08:33 PM
wreaton24
Apr 23, 2019 08:00 PM
DieHard
Jul 14, 2017 09:19 AM
lotek10101
LR2
Jan 26, 2016 02:26 PM
a_wick_2010
LR2
Jun 11, 2015 02:58 AM
