Aftermarket turbo for LR2?
Old Mar 31, 2023 | 08:25 PM
Ironwill723's Avatar
4th Gear
Default Aftermarket turbo for LR2?
Can anyone recommend an online site for an after market turbo for an 2015 LR2 2.0? I realize BW turbos are preferred but I do not want to deal with the cracked manifold issue again.
I was leaning towards RockAuto.com but I have seen some others that look OK as well. Thanks for the help.
RockAuto:
https://www.rockauto.com/en/moreinfo...&pt=5764&jsn=8
Stigan:
https://www.buyautoparts.com/buynow/...553_sg?src=pla
TurboTurbos:
https://turboturbos.com/products/tp02-0146-32#
Old Apr 2, 2023 | 12:02 PM
LR2.bc.ca's Avatar
4wd High
Hi, if it helps, I replaced the turbo and assembly on my 2012 Evoque using one from Rock Auto and had no issues- depends how long you are considering keeping it I suppose. Could not beat the price. Luckily I had an extended warranty which covered it.
Old Apr 2, 2023 | 05:48 PM
4th Gear
Thanks for the response... Do you remember which one you bought? I believe they have two different ones for sale.
This one made by GPD:
https://www.rockauto.com/en/moreinfo...t=5764&jsn=398
or this one made by Rotomaster:
https://www.rockauto.com/en/moreinfo...t=5764&jsn=399
I just purchased the car with 60k miles so I want it to last a while. Thanks for the help!
Old Apr 2, 2023 | 05:57 PM
LR2.bc.ca's Avatar
4wd High
Sorry, this was for the catalytic converter, my bad
I just looked up my order and it was this one https://www.rockauto.com/en/moreinfo...&pt=5808&jsn=9
DAVICO 17523
Old Apr 2, 2023 | 06:07 PM
4th Gear
Ha! No problem. Thanks for looking into it for me.
Old Jul 4, 2023 | 10:16 AM
alex_moon's Avatar
5th Gear
If you have not found a turbo yet, here is the one that I just purchased. https://turbochargersdirect.com/new-...ur-100202-ftn/
I stumbled upon a 5 min YouTube video from Pawlick Automotive out of Canada where they talk about a replacement turbo/manifold that has worked well for them. I sent them an email and they provided the link that I shared above.
I am about to tackle this project on my daughter’s 2014 LR2. If you managed to already get one installed, I wouldn’t mind hearing how it went.
Old Jul 4, 2023 | 08:34 PM
4th Gear
I ended up ordering a Borg-Warner oem unit direct from the UK. Had it installed with a local shop back in May. No problems with it since. Turbo cost around $1000 from Island4x4.co.uk and install was around $750.
Old Jul 5, 2023 | 11:27 PM
flyingscot's Avatar
that is a good deal....
Bbg
LR2
Mar 6, 2023 07:08 AM
drzjoint
LR2
May 21, 2009 07:04 AM
mikem
Other
Mar 30, 2007 10:35 PM
05LandRover
Freelander
Dec 18, 2006 04:17 AM
